hello, i use paper Gse very often, i have made over 300 pages of paper GSE and 100 GSE jetways, and the glue that works the best is super glue 100%. I use a brand called Original Super Glue can get a pack of 2 at the dollar tree, and I recommend the gel version as you can see where you put the glue better, I also recomend to use tweezers to hold your glue in place as it dries in seconds, and does not come off. Also higly recomend using cardstock paper for best results. Hope this helps good luck!
