Airport Grass
MH aviation
Hi all, as I am finishing up my model airport, one of the last steps is to lay grass.
i dont know what is best as there are so many options. if anyone knows good ones that are easy to find in North America please let me know
thanks
thanks
Do you have a Hobby Lobby store near you? They have different kinds of hobby grass that I’ve used for 1/400 airports in the past. Reasonable prices too.
Yeah that's what Hobby Lobby had
Yeah Model Train Grass
(what I taught midwest as well as a few others)
I do N scale trains and this helps a lot.
Get Woodland Scenics grass
Spread some white glue watered down about 50/50
then add the grass and coat the top with the watered glue again
Works great
Works great
This technique does works well
Use scatter grass instead of a grass mat. The mat usually come off after a while even with good glue. But the scatter material does not. It also works better. But it is a bit messy
You need to also consider the scale that we are working with, scattered grass which is my preferred choice too, may be applied in certain areas where the grass is taller, where you may have to reduce the consistency for other areas. Sometimes finely applied paint can convey grass at 1:400 scale better. A mix of both techniques is best. Have fun! S
Hats off to you, that looks excellent! Far better than a simple grass mat could do. I will have to try it!
Hi everyone, after 4 months the airport is finished (i used a grass mat)
i will be making a separate thread about it and will post pics there.
Thanks for all the help.
Matthew
