Model Aircraft Photography
Citrus Aviation
Howdy, folks! As my first post on this what I hope becomes a fabulous forum to discuss model airplanes I wanted to talk about how to shoot model aircraft in the great outdoors! This thread is an in-depth discussion on how to shoot your models! I have become known for taking incredible outdoor shots and wanted to share some secrets and how to do it with your models! I hope y'all find this thread helpful and look forward to seeing your great shots below!
What is needed?
All that is needed to get started is a model to shoot and a camera. While a DSLR will allow for more manual adjustments, even just an iPhone will work just as well. It is more about how the image is shot and less about the equipment used.
How to Take the Pics
Taking photos is all about matching the aircraft to an interesting sgubjectmater or background along with good lighting. When shooting a model plane a few things should be kept in mind:
1: Lighting should be with the sun behind you.
2: Rule of thirds is generally advisable. However, creative framing such as with the Allegiant A320S below can make of some cool shots.
3: Keeping the titles of the plane in focus tends to lead to a more pleasant viewing experience.
4: Centering and leveling the aprcfafvt to be square and in the middle of the shot also leads to a more pleasant viewing experience.
If you are spotting with a DSLR on a fully sunny day I recommend going for setting similar to these:
F/Stop F/9-F/11
Shuttle Speed 1/640-1/800
ISO 100-200
Editing
When you get home from your outdoor shoot editing will take your photos from the RAW file to a stunning image! I personally use Adobe Lightroom and Photoshop, but most basic editors will allow you to edit the images in a satisfactory manor. It is usually a good idea to make less corrects if shooting with a DSLR. It is then good to increase the sharpness and detail of the image. I will then next increase the exposure slightly as well as vibrance and saturation. These adjustments should be done in modernity or else the image will look over processed. I use Photoshop for unwanted object removal such as removing a stand from an image. You can see examples of that with the Midwest CR and Royal Jordanian 788 images. In addition for images with a sky background I remove dust pots as they can be easily seen with the solid color background. Dust spots look bad on images and removing them makes the photos look more professional. The final step is to export the image. I always export at full resolution so that if I want to reduce the image size later, I can just duplicate the dull res version, take it into PS, and downsize it there.
Once all this is done, you have an incurable outdoor model photos! This sequence works for model airport setups as well which I hope to experiment with in the future. Thank y'all so much for reading this thread! Go out there snd enjoy your collection!
Outstanding tutorial, Citrus! This is gonna be quite helpful for anybody looking to take their photography to the next level!
Shooting scale models against a full size background can be tricky and unrealistic for me. I have found that building scale dioramas is the way to go, unless you just have your model 'in flight' against a real sky. Also using a part real background picture pasted on a board with added scale accesssores can add realism and scale depth. Here is one of my 1/200 AK200 RAF Argosies about to depart from a Middle East airfieldXR106 Argosy C.1 RAF ASC AV200 1-200 scale APR 2013 (3).JPG
That looks superb, I've tried to emulate something similar before but never had much luck making it look all that good.
Shooting scale models against a full size background can be tricky and unrealistic for me. I have found that building scale dioramas is the way to go, unless you just have your model 'in flight' against a real sky. Also using a part real background picture pasted on a board with added scale accesssores can add realism and scale depth. Here is one of my 1/200 AK200 RAF Argosies about to depart from a Middle East airfieldView attachment 493
To each their own! Full outdoor photography has worked for me but though many tens of hours of practice. Your diorama setup is really nice even including the dessert scenery going all the way to the photo/painted background adds a nice layer of depth. How did you shoot the spinning props? It's a super cool effect!
To each their own! Full outdoor photography has worked for me but though many tens of hours of practice. Your diorama setup is really nice even including the dessert scenery going all the way to the photo/painted background adds a nice layer of depth. How idd you shoot the spinning props? It's a super cool effect!
Thanks for that. The spinning props were 'powered' by a hair dryer running at full blast just out of shot.
Did you get the hairdryer out for that photo?
