My model airport.
I have been working on getting my main airport to look and function the best it can but I would like some criticism to improve for the future I will include a photo!!
I will be fixing one of the taxiways into the runway (by making it wider) for now it is blocked off
I have also added a area near the terminal for ground service equipment and cargo at the moment I only have a Qantas 707 that I use as a cargo aircraft more to come in the future
Thank you all, if you guys would like to y’all could follow my instagram: mirage2000__5
I post pretty often small updates of new routes/models and overall the entirety of the airport.
Looks pretty good the taxiways going on/off the runway are a bit thin but it might just be the picture
As I said I would update you guys. Just wanted to ask if this is reasonable enough for the runway exit/entry that I’m expanding if not I will cut off more grass.
I'm liking it. That looks just a bit tight to me. If it were me I'd make it just a bit wider.
I May or May not i will paint and sand the residue from the grass I peeled off. Since my airport mostly operates narrow body’s at the moment I believe this is quite alright for now may expand it a bit more though thanks!
Yeah for a narrowbody looking good but for a widebody probably not the best you could restrict the taxiway to RJs and narrowbodies only if you wanted
